spring isolators
spring isolators
If when installing the rear springs i do Not use isolators will it really cause much more noise, and or wear? and what about the front isolators? and if i install new rear isolators and not front or other way around with lowering springs (sportlines) will it be raised too much in either the front or back? or just reuse them all if i can, OR just use thecut up garden hose?
THANKS
THANKS
Catmaigne
07-14-2015 05:17 PM
