Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 07-11-2011, 07:52 PM   #1
Cbystrack's Avatar
rear end gear help??? cant find any
i have a 1987 camaro iroc-z that has the disc rear brakes, 9 bolt borg warner (prob spelled wrong) rear end that i can not for the life of me find any gears available??? Can anyone point me in a 4:11 direction? lol or am i looking to be starting a 10 bolt drum conversion?? thanks- Chris
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1997 Pontiac Trans Am WS6 LT1, flowmasters, ram air
2001 Chevy Tahoe LS 5.3
2001 Honda Rancher 350 lifted on 28's hmf exhaust/jets
Bystrack Motorsports
Cbystrack is offline   Reply With Quote
Old 07-11-2011, 09:54 PM   #2
Re: rear end gear help??? cant find any
check 9 bolt.com, im assuming you have already calle DTS, richmond and some of the other companys? check with yukon gear, i wanna say i "think" they offer a ratio that stout.
__________________
Richard
89 formula LB9 WS6 T-5
83 T/A 350 T-5
run it wide open till ya see god "THEN" brake !
quickchicken is offline   Reply With Quote
Old 07-12-2011, 07:25 AM   #3
Good luck trying to find gear sets for the BW 9-bolt. Very few are avaiable, with a 3:70/3:73 ratios being the lowest.
87DJP2001 is offline   Reply With Quote
Old 07-12-2011, 04:36 PM   #4
Cbystrack's Avatar
yeah its very hard, im lucky to have the 3:70's but its an 1/8th mile car and i want lower..... how hard is it to swap to a ten bolt?
__________________
Old 07-12-2011, 07:55 PM   #5
calaban's Avatar
I have the same rear. I'm planning to find a 4th gen rear with a 3.42 gear. It'll swap right in and the pics I've seen of the width difference is barely noticeable unless you know or know enough about 3rd gens to see it.
__________________
1995 Camaro Z28 - 6 speed, T-top Conversion, CAI, Air Foil, TB Bypass, 160* T-stat, manual overide fan switch, J&M SFC's, Flowmaster ### 1989 IROC-Z - L98, auto - Stock restoration in progress
calaban is offline   Reply With Quote
Old 07-12-2011, 08:18 PM   #6
Cbystrack's Avatar
i hear ya calaban, the 9 bolts have what your looking for gear wise. im building mine for the 1/8th so i want more towards a 4:11 ish which i found on 9bolt.com. i have a set of 3:23's, and 3:70's ill see ya if you want to go that route.... where in NC are you?
__________________
Old 07-12-2011, 09:23 PM   #7
calaban's Avatar
Goldsboro area.
__________________
Old 07-13-2011, 06:59 PM   #8
Cbystrack's Avatar
im in the greenville area we oughta hit up a track sometime!
__________________
Old 07-15-2011, 08:54 AM   #9
calaban's Avatar
I've been to Kinston once, but that's was several years ago.
__________________
Old 07-21-2011, 01:19 PM   #10
Stevolwevol's Avatar
You could try Summit Racing. You might pay more for new stuff, but chances are they have what you want.
Stevolwevol is offline   Reply With Quote
Old 12-06-2011, 06:03 PM   #11
1987IROC350's Avatar
I haven't been on the site for quite a while but when I was looking I found that ringpinion.com also had a lot of stuff for our BW 7.75" rear.
Here is a set of 3.73's for it. Sorry for posting in an old post ha.
http://www.ringpinion.com/b2c/Produc...ets&Source=Wiz
__________________
'87 IROC T-Top:Crate Vortec 350 TPI W/hot cam, Edel. run, 52mm tb, K&N, 3" catback, Edel. TES shorty, 700R, 2800 stall W/cooler, Hurst dual gate shft, '01 WS6 Alum.shaft, BW 9 bolt 3.27 w/posi, pro-kit, twr. brace
'03 Mach 1 13.8@102 stock w/auto.
1987IROC350 is offline   Reply With Quote
Old 01-01-2012, 06:34 PM   #12
Quote:
I take it you are not going to drive this car on the street? What transmission are u running? you are using the tpi too?
birdman11 is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Where do you find gear paint to check gear pattern? blue Drivetrain 4 11-05-2006 05:02 PM
How do I find out what my differential/final gear ratio is? Brangeta LT1 Based Engine Tech 5 02-12-2005 09:34 PM
How to find out the gear ratio in your rear end? quickslick86 3rd Gen / L98 Engine Tech 7 07-25-2003 06:21 PM
how can i find what size gear i have mickeyiz28 LT1 Based Engine Tech 1 04-27-2003 04:23 AM
Rear end gear is broken - who does gear swaps in GR? one wicked element Midwest 5 09-16-2002 03:41 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
