Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 06-01-2010, 01:39 PM   #1
Question No injector signal
Turn the car on and the fuel pump doesn't kick on, first thought was burnt up. Ran a jumper wire and the pump still works, pressure is good. I checked the injectors with a noid light and nothing. Would a bad pump relay cause the injectors to not receive a signal from the PCM? Car still cranks fine and still gets spark.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
Lawrence
'92 Z M5
'94 Z LS1 mod
RIP: '99 Z28 Yellow, '98 B4C black
laZy is offline   Reply With Quote
Old 06-01-2010, 10:54 PM   #2
Sorry no help here. Maybe you can help me. Where did you get your noid light. I've wanted one for years but cannot find one.
__________________
1989 Firebird Formula, 305 TBI, auto, 100% stock
1989 Firebird Formula, 350 TPI, auto, 100% stock
1991 Camaro Z-28, 350 TPI, auto, 100% stock
2001 Camaro SS, LS1, auto, 100% stock
cars3 is offline   Reply With Quote
Old 06-02-2010, 11:32 AM   #3
Matco truck.
__________________
Lawrence
'92 Z M5
'94 Z LS1 mod
Old 06-02-2010, 03:14 PM   #4
Sounds like a VATS problem. Does the security light stay on?
If the VATS checks out OK, you may have a problem with the distributor pickup or ignition module.
__________________
1985 Z28
2000 TA
Marc 85Z28 is offline   Reply With Quote
Old 06-04-2010, 12:40 AM   #5
Quote:
Originally Posted by laZy View Post
Matco truck.
Thank you very much. Matco comes to the maintenance dept. where I work on fridays. I'll ask him about one.
__________________
Old 06-04-2010, 02:08 AM   #6
Click the image to open in full size.
I had been going through some of the wiring in the car and trying to fix some of the hacked jobs. Unfortunately this is my first 3rd gen so some its new to me, I can do a 4th gen from memory. The photo above is what I encountered with the + battery cable, didn't know what it went to. Still not sure about the blue wire but the red 14g wire in the weatherpak conn was the culprit, THIS WIRE MUST BE CONNECTED. Long story short, checked the fuse by the battery and it was good then checked all three relays by the brake booster and they were good. I remembered those wires and said what the hell, put a jumper to the blue one and nothing then the red one and the clouds parted the sun shone and angels sang
Old 07-10-2010, 12:59 AM   #7
If your pick up coil is bad or on its way it 1)injectors wont fire. 2)no spark at coil. One symptom can occur or both at the same time. check ohms at two wire connector at dizzy by touching both connectors. It should read 500-1500 ohms. Then touch one prong and ground to the dizzy there should be no ohms or continuity. If either fail then its the pick up coil. The pick up coil gets the signal first then transfer to coil then IGM and runs from there.
TL-type-S is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
