exhaust pipe restriction
i have an 84 Z28 with a 283 in it. its pretty powerful for a 283, 041 heads, 9.5:1 compression, cam with 278/288 adv duration, 204/214 duration at .050, and .422/.444 lift, performer intake and 600cfm carb and headers. its nothing special but its a LOT faster than a stock 305. the problem i have is that i had a y-pipe made for the headers i have. the guy mad it 2" coming off of the collectors into 2" for another 6" after the "y" or "T". the pipe is tiny, its about the size of 1, 1 3/4" primary tube that is on another car i have because it has a bend in it also. i put a fuel pressure guage in the hole for the 02 sensor and reved it to 6000 in park. the guage would go up to about 7-10 psi which is a lot for backpressure. how much psi do you think i would get at WOT while driving it? and about how much do you think it is hurting me?
also, could it be hurting gas milage much? thx
it has a 3" catback, no cat, with a flowmaster muffler.
i've been thinking of just getting hedman headers and the y-pipe that fits with them but i've heard of the y-pipe hitting the oil pan. i have an aftermarket oil pan though so i don't know if that would be any better.
it looks like its about the same size pipe but mine comes together to make a T. if you can just fit your fingers around the pipe to touch then its about the same size.
the SLP pipe is for stock manifolds isn't it?
Noct
05-26-2016 10:26 AM
drptop70ss
05-04-2015 08:22 PM
