LT1 Swap: How do you hook up MAF?
Old 04-23-2006, 08:39 AM
Rage's Avatar
I went to connect the MAF from my LT1 to the connector on the stock 87 lid and I ran into a problem. the LT1 MAF is a 3 pin connector, my stock MAF is a 5 pin. Is there anyway to splice my old sensor into the new? What did you do?
Rage is offline
Old 04-23-2006, 04:44 PM
89Vert's Avatar
Re: LT1 Swap: How do you hook up MAF?
so are you tring to run your 87 ecm with LT1 MAF?
cause that won't work,
the MAF's don't work the same
89Vert is offline
Old 04-23-2006, 05:04 PM
jah1542's Avatar
Since I'm not a third gen guy, I'm probably wrong, but weren't all third gen engines speed density?
jah1542 is offline
Old 04-24-2006, 11:44 AM
Rage's Avatar
No and No. Im running the LT1 ECM and wiring harness but the MAF plug itself on the LT1 harness is a 3 pin, the receiving part of the MAF on my stock lid is a 5 pin.
I believe MAF was used on all TPI units until 1990, then they switched to SD.
Rage is offline
Old 04-24-2006, 11:54 AM
LWillmann's Avatar
You're probably going to need an LT1 MAF then.
LWillmann is offline
Old 04-24-2006, 12:58 PM
89Vert's Avatar
so you are tring to run stock maf with LT1 ECM and harness?
have to get the LT1 MAF
89Vert is offline
Old 04-24-2006, 01:02 PM
89Vert's Avatar
for some reason they went SD in 90,
IMO MAF is a better,
but on a 3rd gen MAF was a limited 16kb file
when they went to SD it got a larger 32kb file, which allows for better tuning
89Vert is offline
Old 04-24-2006, 01:29 PM
fast 93 z's Avatar
2 pins out of the 5 pin connector may be for a IAT sensor.
fast 93 z is offline
Old 04-24-2006, 01:52 PM
89Vert's Avatar
maf burn off I belive, they have an IAT sensor on the plenum
89Vert is offline
Old 04-24-2006, 03:29 PM
fast 93 z's Avatar
Oh ok...I have seen some Mafs have the IAT built into the sensor.
mr28
04-20-2016 05:44 PM
Injuneer
12-15-2014 09:36 AM
pete53
12-09-2014 07:31 AM
formula218
12-02-2014 04:27 PM
Camaro90RS
07-23-2002 07:57 AM
Quick Reply: LT1 Swap: How do you hook up MAF?
