fuel delivery
Old 06-26-2004, 08:37 PM
jer
jer's Avatar
fuel delivery
any one smarter then me
okay should i use the manual fuel pump on the block of the engine? or ... should i use the fuel pump in the gas tank?
if i use the manul fuel pump can i just pull the fuse for the electric one in the tank? or is it safe to use the electric pump on a vac. sencondary carb?and just put a block off in the engine pump hole
thanx. jer
jer is offline
Old 06-28-2004, 10:44 AM
aklim's Avatar
If nothing is wrong with the pump in the tank why not use it?
aklim is offline
Old 06-28-2004, 01:17 PM
jer
jer's Avatar
no there isn't any thing wrong with the one in the tank but i wasn't sure if i could use it with a carb
jer is offline
Old 06-30-2004, 04:59 PM
thezisking's Avatar
If you're running a carb, you'll need one on the block. The fuel pump in the tank will have too much pressure for a carb.
thezisking is offline
Old 07-02-2004, 04:55 PM
jer
jer's Avatar
okay can i just pull the fuse and let the manual pump syphin throw the electric pump in the tank ?........also the pump in the tank was for a 2.8 l engine and the new engine is a 5.7L whats the presure rating for both if you know?
thankyou
jer
jer is offline
Old 07-02-2004, 06:11 PM
greezemonkey's Avatar
You could run the electric pump ....you just need a regulator to keep the pressure down to around 6 psi. I have a mallory 4 port, it`s been running my car 5 yr`s at least...so no issues with longevity or however you spell that :-)
greezemonkey is offline
Old 07-03-2004, 03:16 PM
jer
jer's Avatar
yeah i just got off the phone with summit gonna get that problem solved thanx evey one
jer
jer is offline
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
944LT1
06-24-2002 10:36 PM
Quick Reply: fuel delivery
