Fixing my tilt steering column: what tools are needed?
Old 08-14-2004, 06:25 AM
firebirdjosh's Avatar
My high beams don't work anymore because the steering wheel is sagging so far down. Its just dangerous now. I already got a steering wheel puller but then I got to the part where you need a spring compressor of some sort and I'm stuck. Where can I get one and what does it cost? Thanks guys!
firebirdjosh is offline
Old 08-14-2004, 07:14 AM
Dave89IROC's Avatar
Re: Fixing my tilt steering column: what tools are needed?
http://www.thirdgen.org/newdesign/te...ngcolumn.shtml
you need a steering column lock plate compressor
after that, it is screws, and few torx bolts(will need torx bit), then, to get to all four bolts that are loose, you need a pivot pin puller
Dave89IROC is offline
Old 08-14-2004, 06:08 PM
buzz12586's Avatar
You need a lot of patience!!! Me and my gf's dad pulled it apart and got almost all the way to the end when we gave up because it was such a pain. This was after about 3 hrs of work. His friend a mechanic came over and did the job in like 30 min. So if you can have someone who has done it before do it.
buzz12586 is offline
Old 08-14-2004, 11:57 PM
Took me 45 minutes to get to the torx bolts. Not too bad I suppose. To get the pivot pins I made my own puller. I just got a bolt that fit, used a 5/8" socket (large enough for the pin to fit inside it), and just started tightening the bolt with it placed straight through the back of the socket. Worked great and no problems with snapped screws and drilling stuff out. I can't wait... new steering wheel, repaired turn signal switch, and a tight column.
Old 08-15-2004, 09:05 AM
http://home.t-online.de/home/O_Scholz/jpg/col19.jpg
I cannot remove that part no matter how hard I try. Its the very last piece holding it all together!!!
Old 08-15-2004, 09:31 AM
Dave89IROC's Avatar
its hooked to a metal rod that goes down to the ignition switch, it should just unhook
Old 08-15-2004, 09:33 AM
Dave89IROC's Avatar
are you using this site?
http://home.t-online.de/home/O_Scholz/steering.html
Old 08-15-2004, 04:17 PM
I got it now, I thought it meant tilt the column, not the lever. That was so much work but I had no horn and my steering wheel fell in my lap, both were not safe. Thanks alot! Luckily no bearings fell out. I did manage to butcher my tilt lever though.
Parts Wanted
03-17-2015 11:24 PM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
Jazsun
12-29-2014 12:14 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: Fixing my tilt steering column: what tools are needed?
