I-Roc Z 1990 Stall start
Old 02-27-2014, 06:19 PM
mikuska24's Avatar
I have a 350 small block 1990 I-Roc Z and whenever I start the car I have to give it gas until the engine heats up. It is fuel injected and it is stored in a garage. After the engine heats up it runs just fine. Any ideas?
mikuska24 is offline
Old 02-28-2014, 03:55 PM
Re: I-Roc Z 1990 Stall start
Could be a problem with the coolant temperature sensor. Based on the reading from the sensor, the ECM raises the idle speed and richens the A/F ratio for cold start.
Injuneer is offline
dale3in98
02-14-2015 12:18 PM
mackirockz
02-04-2015 07:03 AM
Amshnock
14
01-18-2015 11:47 AM
Quick Reply: I-Roc Z 1990 Stall start
