2010/11 front license plate bracket solution
Old 10-07-2010, 09:15 AM
km9v's Avatar
Thumbs up 2010/11 front license plate bracket solution
This seems to be the be solution I've found to attach a front license plate to the front of the car w/o drilling or costing a lot:
3/16" x 1 1/4" washers
1/8" x 3" toggle bolts
sticky back foam or felt.
http://www.camaro5.com/forums/showthread.php?t=73549
km9v is offline
Old 10-07-2010, 10:17 AM
km9v's Avatar
After a little more digging, i found that you can turn the bracket upside down & mount it lower:
Lower:
Upper:
Which do you think looks better? Upper or lower?
km9v is offline
Old 10-09-2010, 08:19 AM
Admin Emeritus
JasonD's Avatar
Thanks for the head's up on how to do this.
And I most definitely prefer upper. It looks centered and intentional. Mounting it lower makes it look "un-factory".
JasonD is offline
Old 06-22-2011, 03:29 PM
PFYC's Avatar
Re: 2010/11 front license plate bracket solution
I'm sorry to bring this back from the dead, but we have found two other solutions for this problem for your Camaro.
1)
Top Flight License Plate Bracket Kit for 2010 2011 Camaro
2)
2010-2011 Chevy Camaro Accessories Store
PFYC is offline
Old 06-23-2011, 08:17 AM
km9v's Avatar
How does the Camaro bracket mount? Is it the same as the other ones displayed?
km9v is offline
Old 06-23-2011, 10:40 AM
PFYC's Avatar
The Top Flight uses 3M automotive grade double sided tape. The other mounts under the car using hardware and is a universal product meant for use on almost any vehicle.
PFYC is offline
06-06-2015 08:27 AM
Brake_L8
01-20-2015 09:44 AM
Z28STYLE23
08-17-2002 07:40 PM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: 2010/11 front license plate bracket solution
