2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
2011 SS Shakes!
Old 03-02-2011, 09:10 PM
T56LS102's Avatar
2011 SS Shakes!
Long story short, I got a nail in my rear pass tire, went to goodyear, had them patch it, now at 75 + mph the car shakes! not too bad, but its definitely there..
I was thinking its probably out of balance, but all it was, was a patch job ...
What do you guys think? thx
T56LS102 is offline
Old 03-02-2011, 09:33 PM
Admin Emeritus
JasonD's Avatar
Re: 2011 SS Shakes!
Get it rebalanced, a weight may have fallen off since the work was done.
If that doesn't do it, consider getting a new tire as it may be unsafe.
JasonD is offline
Old 03-03-2011, 10:33 AM
T56LS102's Avatar
Re: 2011 SS Shakes!
Thanks Jason, Dang a new tire is gonna kill me I'm sure $$$ ... lol
T56LS102 is offline
Old 03-03-2011, 01:21 PM
Admin Emeritus
JasonD's Avatar
Re: 2011 SS Shakes!
Better to have the new tire kill you financially than the old tire kill you literally!
JasonD is offline
Old 03-03-2011, 01:38 PM
chevy_dude97's Avatar
Re: 2011 SS Shakes!
Agreed
chevy_dude97 is offline
Old 03-03-2011, 02:27 PM
T56LS102's Avatar
Re: 2011 SS Shakes!
So for lunch I went back to goodyear, and sure enough it was off balance, so they rebalanced it, we'll see how it feels on my drive home.
T56LS102 is offline
Old 03-03-2011, 09:35 PM
T56LS102's Avatar
Re: 2011 SS Shakes!
I am now home, car feels like new again!
T56LS102 is offline
Old 03-03-2011, 09:54 PM
Admin Emeritus
JasonD's Avatar
Re: 2011 SS Shakes!
Awesome!
JasonD is offline
Old 04-14-2011, 12:36 PM
tomunc's Avatar
Re: 2011 SS Shakes!
I'm with Jason on this. My 2011 SS doesn't shake AT ALL. In fact, I have to be extremely careful when not using cruise control on the highway. At times when the road's not too congested I look down at the speedometer, which I keep on digital display, and find myself going 82-85 MPH. It's SO SMOOTH it gets away from me at times.
My guess is that you threw a weight. Get it checked as your tire is taking a beating.
Edit: Ah...OK. I didn't read the rest of the thread before responding. Glad to see that all is well and you are safe!
tomunc is offline
Old 04-14-2011, 03:08 PM
jg95z28's Avatar
Re: 2011 SS Shakes!
FWIW, I would never take my business to that shop in the future.
When I was in college and worked p/t as a pump block attendant for a local service station, if we removed the tire from the rim to do a "patch" we would always re-balance the wheel/tire after remounting. It was a given. The tire almost never remounts the exact way it was prior to removal and re-balancing should be mandatory in most reputable shops. It sounds like they were cutting corners.
jg95z28 is offline
Old 04-14-2011, 08:42 PM
Lowridah98's Avatar
Re: 2011 SS Shakes!
I have a screw in my drivers rear and it has been there since last fall. Luckily I have tire warranty so it saves me the $600 the rear tire costs. Tire is not leaking air so dealership does not think its punctured. Here's hopin they pull the screw and the tire is fine.
Lowridah98 is offline
Old 06-11-2011, 04:16 PM
shalandah's Avatar
Re: 2011 SS Shakes!
the tire on drivers side in the front shakes at 35 and 40
shalandah is offline
Old 06-12-2011, 05:50 PM
Admin Emeritus
JasonD's Avatar
Re: 2011 SS Shakes!
See above...
JasonD is offline
Old 06-19-2011, 07:47 PM
Kevin Blown 95 TA's Avatar
Re: 2011 SS Shakes!
Also maybe loosen the wheel and torque the lugs - see if that helps. I've had garages screw that up good.
Kevin Blown 95 TA is offline
Old 09-08-2011, 07:42 PM
bossco's Avatar
Re: 2011 SS Shakes!
Still might be an issue. If the screw penetrated deep enough into the tire to expose the belt package but not enough to penetrate the inner liner its still a problem since it exposes the belt package to the environment and that might result in a failure down the road. As a rule of thumb just about any penetration in the grooves on the tread area should be suspect and any penetration in the tread block deeper than 2/32nd's should also be suspect. Granted this means nearly all penetrations into the tire will be cause for inspection (and by inspection I mean disassemble the tire assembly) and repair but the only way to ensure a tire is safe is to completely seal the tire inside and out using a rubber plug and a patch adhereing to proper manufacturer (usually RMA compliant) repair standards.
This may or may not void the speed rating on the tire as well as it depends on the tire manufacturer's guidelines.
Fortunately tires are ruggedly over engineered and catstrophic results are relatively low (the industry also keeps a lid on this stuff since its been a field day for tort lawyers) unfotunately its created a situation where drivers and tire techs take them for granted.
bossco is offline
ryanhilsgen
9
09-21-2015 07:34 PM
cmsmith
09-14-2015 09:25 PM
08-05-2015 08:35 AM
C4m4roJoe
07-19-2015 10:59 PM
Quick Reply: 2011 SS Shakes!
