Our 2010 Single Turbo
Old 10-16-2009, 04:36 PM
Eric@Victory Racing's Avatar
After a little bit of research we have decided to build a turbo kit for the 2010 Chevy Camaro. We have built kits for various other vehicles from Ford Mustangs to Pontiac Aztecs so we are well versed in this subject. All our kits are fabricated in house using 304 Stainless pipe for the hot side and polished aluminum for the intake.
-Polished Turbonectis TC76 turbo (water cooled, split housing)
-JGS 50mm Wastegate
-JGS 54mm Blow Off Valve
-Front Mount Intercooler
-Upgraded Fuel Injector
-Boost-a-Pump
-SCT Tuner
Thanks,
VRE Staff
"Ask us about our vehicle pick up and drop off services"
Eric@Victory Racing is offline
Old 10-18-2009, 12:27 PM
Prorac1's Avatar
What kind of HP numbers did it put down. Eric L
Prorac1 is offline
Old 10-18-2009, 03:23 PM
Just got the fitment jigs made and the pipes CMM'd so we will be dynoing it soon. If you are going to SEMA be sure to stop by and check it out at the Savini Forged Wheels booth.
Old 10-20-2009, 12:55 PM
CALL911's Avatar
Its great to see someone taking a jump on such a potential car and engine. Great job
How much boost are you planning on running? Also, with all the supporting mods, but still stock internals, what would you consider to be the limit boost wise to keep things safe?
CALL911 is offline
Old 10-20-2009, 03:11 PM
We are projecting 600rwhp/600ftlbs at 8.0-9.0lbs of boost. That is very attainable with our kit and will need no other supporting modifications. We already include upgraded injectors and boost-a-pump.
Old 10-20-2009, 10:22 PM
CALL911's Avatar
What about the safe boost level for stock internals?
CALL911 is offline
Old 10-21-2009, 06:57 AM
2010_5thgen's Avatar
projecting 600 but howm uch did it put down? how much $?
2010_5thgen is offline
Old 10-21-2009, 07:01 AM
The complete kit is $7499.99.
We have 2 kit completed so far and should have 1 on the dyno soon. We are just under the time constraint for SEMA. Hopefully I can fit it in next week before we leave for Las Vegas.
Old 10-24-2009, 06:39 PM
Mattsv8's Avatar
could a larger turbo be used like a 88mm or 91. im looking for a kit to support 1000-1200 whp. of course this will be a fully modded motor, proably a powerglide. im trying to get sponsorship and go for some records.
Mattsv8 is offline
Old 10-26-2009, 05:21 AM
Yes, we are looking at some large frame turbos with billet wheels for our larger HP customers.
Old 11-04-2009, 07:54 PM
Old 11-05-2009, 11:55 AM
Gripenfelter's Avatar
Can't say I'm a fan of rubber band tires.
Gripenfelter is offline
Old 11-05-2009, 04:38 PM
CALL911's Avatar
Any word yet on the safe boost level to keep with the stock internals?
CALL911 is offline
Old 11-06-2009, 07:12 AM
i am
Old 11-08-2009, 09:11 AM
We have seen 8 pounds from other peoples kits, but we will have an official number for ours on Friday.
Quick Reply: Our 2010 Single Turbo
