Cold Air Intake?
Cold Air Intake?
Hello:
I am scouring the forums to get a consensus.
I am a newbie when it comes to Camaros. My last car was a Ford Focus and I upgraded this year to a '10 SS and now I want more power.
My friends tell me a cold air intake is the way to go (cheap price, good power). I did some research and came across this company (www.fastlaneturbo.com) and their Pipeline Cold Air Intake.
It seems decent but I want to get a second opinion. Does anybody know about this company and their cold air intake? I am scouring the forums to get a consensus.
Here is a blurb from their website. Thanks!
This is a massive 4” true cold air intake that draws air from the lower grill opening of your 2010 Camaro. The “Pipeline Air Intake” provides two key benefits for your Camaro. The first being that the system scavenges cool air from below the vehicle rather than hot “under hood” air, that provides lower air inlet temperatures and cooler air that carries more oxygen into the engine. This translates into a more intense combustion process creating more horsepower and torque. Secondly, the system benefits from a “ram air effect”- when driving down the road providing more air into the engine helping it “breathe” better. The system features 4” aluminum construction, CNC machined MASS Air Flow Meter flange, the intake integrates with the factory PCV system, and an Oil-Free lifetime dry air filter. The System requires simple one bolt relocation of windshield washer reservoir. All parts are included with “The Pipeline Air Intake”. This intake is now two mandrel bent pieces.
This kit will also work with Magnusson Superchargers as well.
Power Increase = 15 RWHP
Labor Time = 1.5 Hrs
*For best performance and optimal RWHP, an ECM Flash is required. Click here to add Custom Dyno Tune 2010 Camaro SS
*Power Increase = 30 RWHP w/CAI & Tune
You know, in my opinion. An intake is an intake is an.....etc etc. Maybe I should rephrase that. If you are looking at a 3" intake, then they're kind of all the same. If the metal is good quality, I wouldn't going for it. I wouldn't buy it, however, if you can't fit a K and N on it, but that would be absurd for them to do, so I'm guessing it's good.
I would recommend a Poly vs a metal one if you are looking for HP...The metal (unless wrapped) gets pretty hot so your sensor will read that temp. The platic or poly ones dont get as hot...
It's up to you, do you want a little more performance or looks...
We design and carry both.
J.
J.
Pick the one that has the best quality filter, looks good, and is the price you want. That method of selection will provide more enjoyment than pulling your hair out to find which one has 1/10 of a HP increase in a +/- 2% throttle window at a cost of $100 more.
In fact, I would simply ignore HP numbers completely. That can be calculated a number of different ways and some are hilariously high.
A.K.A., me acquiring my intake pipe off of eBay and then putting a K and N filter on it. 1 small bend and very short. Doesn't really do much for the "cold" part of the intake since it isn't very long and doesn't extend down a whole lot, but air flows like "no manana."
All good advise, I looked at the kits that draw air from down low But, what else do they draw in from down low I wondered? Dirt and dust maybe? rain off the traffic in front of me maybe? I went with roto-fab, love it.
I would recommend ADM, Cold Air Inductions, and Roto-Fab. The first two a closed-box designs and have shown very good results and look nice too. The third is sealed by the hood like most and also has shown good results and looks great IMO! It comes in any color! Check out Jannetty Racing. They have tested them all on the same car for great reference and they are also great to buy from.
Sent from my Droid using Tapatalk
Re: Cold Air Intake?
We've got a wide selection of intakes when you are ready. I agree with the others - they are all about the same and unless you're racing for money and have access to a wind tunnel for real testing, you won't ever see big gains on one versus the other in daily use.
We're a proud forum sponsor, have been supporting GM and Camaro fans for almost 13 years, and have a HUGE selection of intakes and everything else. Better yet, our low price guarantee is the best in the business and on top of that, we offer reeward points with each purchase that you can redeem for future cash discounts (assuming you sign up for a login during checkout)...Come and check us out sometime:
2010-2011 Chevy Camaro Accessories Store
94z28jbw
09-08-2002 03:22 PM
ezcheeze15
08-26-2002 01:28 PM
slothgrant
08-22-2002 03:01 PM
