CamaroZ28.Com Message Board
-   Wheels and Tires (https://www.camaroz28.com/forums/wheels-tires-49/)
-   -   Please help!!!! (https://www.camaroz28.com/forums/wheels-tires-49/please-help-861130/)
Murphdizzzl Apr 23, 2012 07:58 PM
Please help!!!! NEED ADVICE ASAP!!!!
will 18x9.5 rims withe an offset of 58 fit my 2001 camaro v6?
link to rims:Corvette C6 Wheels
Injuneer Apr 24, 2012 05:00 PM
Re: Please help!!!!
I run 17x9.5 with 56mm offset. The 2mm difference (58mm vs 56mm) will increase the backspace of the wheel by less than 1/10th of an inch. Since you are looking at a larger diameter wheel, and the steering knuckle is curving backwards more relative to the edge of the wheel, as wheel diameter increases, I would say they will work.
OE Wheels specifically says "Camaro, Firebird and Trans am 1993 thru 2002. Fitment provided for stock vehicles only." I would simply verify with OE Wheels.
Re: Please help!!!!
Murphdizzzl Apr 24, 2012 08:43 PM
Re: Please help!!!!
kool i have 20x8.5 withan offset of 15 that rub bad and make really loud grinding noises
thanx for the info
