Maybe a newb ? but are all ZR tires Z-Rated?
Old Sep 11, 2006 | 05:48 PM
Lunch Box's Avatar
I'm just not sure if all ZR tires (eg 245 50 ZR 16) have the Z Speed rating or not. If anyone can help it would be greatly appreciated, thanks. I tried a couple searches in this forum without any luck.
Old Sep 11, 2006 | 06:19 PM
87DJP2001's Avatar
Re: Maybe a newb ? but are all ZR tires Z-Rated?
If it has a "Z" in the tire size it is Z-Rated.
Old Sep 11, 2006 | 06:36 PM
Lunch Box's Avatar
thanks for the help, i thought as much but wanted to be sure
Old Sep 11, 2006 | 07:19 PM
Bayer-Z28's Avatar
Yep, You'd be right... 'Z' is speed rating 'R' means radial.
Old Sep 11, 2006 | 09:20 PM
Dave '97 Z28 M6's Avatar
Additionally, there are 2(or 3) numbers and one letter after the (for example) P245/50ZR-16 - this is called the service description. The number corelates to a load rating, and the letter a speed rating. If the letter is a W, the tires are rated for sustained 168MPH, if the letter is a Y, the tires are rated for sustained 186MPH. If there's no letter, the tires speed rating reverts to the original Z spec, which is simply "over 149MPH".
Old Sep 13, 2006 | 05:08 PM
Bayer-Z28's Avatar
Or otherwise called an "Aspect Ratio".... ex..245/50 ratio of the width of the tire to the height of the sidewall..
Old Sep 13, 2006 | 06:04 PM
I wasn't refering to the aspect ratio. An example:
P245/50ZR-16 89Y
The "89Y" is the service description of the tire... the 89 means it has a load capacity of 1279lbs, the Y means it is rated for sustained 186mph.
Old Sep 13, 2006 | 06:20 PM
87DJP2001's Avatar
[QUOTE=Dave '97 Z28 M6]I wasn't refering to the aspect ratio. An example:
P245/50ZR-16 89Y You can not have a tire with two different speed ratings on it. Your example "Z" & "Y".
Old Sep 13, 2006 | 07:24 PM
The "Z" part means the tires are rated for 149+mph, the "Y" part clarifies it as 186mph.
Check it out, near the bottom of the page...
http://www.tirerack.com/tires/tirete....jsp?techid=35
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
