All People 255 all around in here..
The people with 255's all around did you have a problem with rubbing? i have heard some work fine and some rub.
If they do rub how would you suject that i fix it so that they will fit. Thanks, Brian |
anyone?
The WS6 and SS cars used 275's all around with no rubbing. I've used 275's on two different sets of 17x9.5" wheels with no rubbing. I can't see why going up 0.40" in width from a 245 to a 255 would cause any problems.
With anything other than a stock wheel, you need to consider whether the wheel has the correct offset, to determine if the tire will rub. |
