CamaroZ28.Com Message Board
-   Wheels and Tires (https://www.camaroz28.com/forums/wheels-tires-49/)
-   -   315/35r17 size differences between brands (https://www.camaroz28.com/forums/wheels-tires-49/315-35r17-size-differences-between-brands-887080/)
JohnSS1927 Nov 19, 2018 04:26 PM
315/35r17 size differences between current brands
Hello,
Between the current brands available, who knows how they run in size and compare to each other:
Nitto NT05
Nitto NT555 G2
Goodyear Eagle F1 GSD3
Thanks!
Injuneer Nov 19, 2018 04:59 PM
Re: 315/35r17 size differences between brands
What specific dimensions ae you looking for?
Tire Rack has
- SUMITOMO HTR Z
- GOODYEAR EAGLE F! GS_D3
.... with dimensions for tread depth, tire weight, acceptable rim width, measured rim width, section width, tread width and outside diameter.
Tire Rack also has a chart comparing various tires, by various classifications of tires (e.g. - high performance summer), showing user rating feedback on things like dry traction, wet traction, dry braking, wet braking, noise, comfort, tread life.
https://www.tirerack.com/content/tir.../homepage.html
The NITTO website has the dimensions for the two you mentioned, but only tread depth, section width, acceptable rim width, overall diameter and weight. No tread dimensions.
https://www.nittotire.com/
JohnSS1927 Nov 19, 2018 05:06 PM
Tire Rack has
- SUMITOMO HTR Z
I understand that, but sometimes those are not completely accurate based on what others have said in comparison on other threads in the past. I'm just looking for real world experiences and opinions of the current 315 options available. Thanks.
Injuneer Nov 19, 2018 11:16 PM
OK...I guess I interpreted “size” as dimensions. Hopefully someone can give you the info you need.
