19x12 wheel question - CamaroZ28.Com Message Board
Old 11-24-2004, 12:07 AM
Not sure if anyone has gone this wide yet but I'm about to order the ROH Modenas in this size, does anyone have the backspacing to have them stick out about 3/4"-1" from the rear quarters? I ask this because I have a custom shop in my area doing custom quarter panel work on my car and rolling the lip of the fender altmost like the ZR1/Sunoco camaro, the wells are being tub'd so im aware of the modifications to the inside. Any ideas on a tire? Ive seen them on Porsche and Vipers but I know we dont have that kind of room stock which is why i cant stay stock
BIGKerneL44 is offline
Old 11-24-2004, 04:27 AM
Re: 19x12 wheel question
or you could get smaller wheels.
BirchMan98z is offline
Old 11-24-2004, 09:16 AM
or i can stick with 19x12 like i planned
Old 11-24-2004, 06:10 PM
you might need to figure it out by going outside and determining the distance from the mounting surface of the rear hub to the edge of the rear fender, then adding the 3/4"-1". this site might help you out a bit:
http://www.skulte.com/adapterfaq.html
also, in case you didn't see it, there is a guy on the following link with 18x13 rears.... they stick out a bit..... might be exactly what you're looking for.
http://www.ls1tech.com/forums/showth...ight=forgeline
i know the frustration, i contacted a "Brand X" company and asked if they made wheels for my car in 18x11, and they said "we sure do, just tell us the offset and backspacing that you want"
hope this helps a bit.... or you could get smaller wheels....LOL
blacksix is offline
Old 11-24-2004, 06:19 PM
Super Moderator
Using the 17x11 GS offset wheel, the "front space" of 4.00" puts the outer edge of the wheel/tire just inside the Firebird fender, when looking straight down from above. That tells me you want a 4.75" - 5.00" front space. For a 12" wheel width you would want something in the range of 44mm (4.73" front space) to 37mm (5.01" front space). That number is calculated assuming a bead retention flange width of 0.466", similar to the ZR1's. If the ROH's have a different flange width, the numbers could vary by a millimeter or two.
After considering the above THEORETICAL calculation, and considering that you appear to be looking at wheels for a Z rather than a firebird, I would verify the numbers by doing exactly what "blacksix" told you to do. Get a straight edge.... put one end of it hard against the axle flange surface where the wheel will mount, and measure out-wards (if you don't add the hyphen to this word, the language filter zaps it - wonder why?) the distance you want the edge of the wheel to sit at. Give that info to the wheel manufacturer, and he knows enough to do the rest.
Injuneer is offline
Old 11-24-2004, 06:57 PM
hope this helps a bit.... or you could get smaller wheels....LOL[/QUOTE]
enough with the smaller wheels talk! lol thats exactly what i was looking for, they will look tucked in after the shop gets done with the rear quarters i was jus looking for an idea =) thanks again blacksix and once again injuneer
BandDirector Blk98ZM6
02-20-2015 08:42 AM
Airplanedoc
02-01-2015 08:14 PM
30thZ4C
Wheels and Tires
01-29-2015 07:03 PM
ChrisFrez
11-30-2014 09:41 AM
redzed
09-04-2002 07:22 PM
Quick Reply: 19x12 wheel question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
