Rebuilt engine/trans/rear perfect for swap
Because my job relocated me to DFW Texas, I'm offering up my wagon for sale. I turned it into my race car that I drove 20 miles highway to the track, raced, and drove home. It still has a full interior but no cats, front and rear bumper supports have been removed. This drivetrain is perfect into an older vehicle or should pass emmissions with the addition of some of the original equipment.
You can see pics here: http://www.cardomain.com/ride/2474119 Below is a list of the good stuff: LT1 383 with approx 500 miles Cast Scat stroker crank Scat forged H-beam rods SRP forged flat-top pistons Total Seal rings gapped for 150 HP nitrous Std volume high pressure oil pump Ported aluminum heads 2.00/1.55 stainless valves CM 612 springs Aluminum roller rockers 230/236 XE Comp Cam Cloyes double roller timing chain New Optispark MSD Coil MSD 8MM Wires NGK Plugs Mezzire water pump S&B air filter 3.5" MAF BBK 58mm throttle body Ported intake manifold SVO 30lb injectors Walbro 255 fuel pump Transmission with about 5 miles Edge 3200 converter Beast shell Billet Servo Kevlar clutches/band Street/Strip firmness Rebalanced DS with HD U-joints DS loop 3.73 National Drivetrain Gears Eaton 400# posi IC CA relocation brackets Sedan springs Air Bags Manual Steering No ABS, A/C Front springs cut to lower 1" Long wheel studs F/R Bryan Herter program AKM Cable IBM Thinkpad Laptop Looking for $3,750 for the wagon including the computer. It's best to email me at othercrap05@yahoo.com |
| All times are GMT -5. The time now is 08:45 AM. |
