LT1 Parts (Comp, BBK, Pacesetter, etc....)
Stock Intake - $40
Stock waterpump - $15 Lifter Spider & Dogbones - $10 SVO 30lb Injectors - $175 MSD 96-97 Coil and ICM Assembly - $45 Pacesetter LT with new O2 sensors - $250 Stock Alt - $25 Proform Valve Covers - $50 Powermaster SBC Mini-Starter - $50 LT4 Cam Gear - $25 Oversized Crank Gear - $25 Stock 4L60E Converter - free Stock Auto Inspection Cover - free 4L60E Dipstick - free Lokar Dipstick (5001) - $35 new Stock radiator hoses - $10 Stock fans, 2 sets - $40 each Gates universal radiator hoses - $20 LSxTune Opti harness - $10 Stock M6 engine wiring harness - $50 Stock A4 engine wiring harness (sensor pigtails missing) - $15 Shortblock - $1,250 Stock 2-bolt block Stock crank Eagle H-beam rods Ross Flat Top Pistons Timing Cover OBD2 Crank Hub and Reluctor Oil Pump drive gear Melling stock replacement oil pump Stock Pan |
Re: LT1 Parts (Comp, BBK, Pacesetter, etc....)
3 Attachment(s)
Sorry for the wait, been busy with kid stuff. Pics in the first post. Also I took pics of everything I had. I've never parted something out completely so if you see something in the pics let me know. I have an M6 cross member and a A4 one as well. Couple radiators, stock and griffin. Couple sets of fans, etc....
Attachment 16230 Attachment 16231 Attachment 16232 |
8 Attachment(s)
*SOLD*
Griffin radiator MAF Madman bracket wires and looms |
Still have the Optispark and headers?
Yes both of those are still available. $200 for the headers and $35 for the opti. If you want the O2's as well it will be another $50.
On the 94 did u run the egr or did u have the block off plates? Also are you firm on the 200 for the RR's?
Also what type? Are the self aligning and what stud size?
Sorry roller rockers are sold. Don't get much action in the Texas forum so I didn't update the list like I should have.
Originally Posted by ulakovic22
(Post 6665449)
Originally Posted by AdioSS
(Post 6665471)
Well get to it! Snap snap! :D
Roller rockers, stock radiator, 52mm TB, LE1 Cam and fuel rails all sold |
Stock timing set, pushrods, lifters, balancer, heads, head bolts, gaskets all sold
MSD 96-97 coil and ICM assembly. $45 shipped to 36360? Thanks.
Originally Posted by zmike
(Post 6666821)
Opti is sold as well. |
