Kid on the way time to sell some vehicles.....
1994 Camaro Z28 Street/drag car
runs 10.45 @ 127 MPH on Nitrous
11.39 all motor
Exterior:
Weld Pro Stars up front
Weld Pro Starts out back
28x11.5x15 Hoosier E/T streets
T-Tops
Cowl hood
Interior:
Adjustable Shift light
6 point welded in cage
B&M reverse lock out pro stick
4-point safety harness (out of date)
Battery relocated to rear
Engine:
LT1 383 Stocker
Scat crank
Eagle rods
12.8-1 compression
Custom ported and polished heads and intake
Hooker long tube headers
Drive train:
Stage III TH400 with trans brake and reverse manual valve body
Custom steal drive shaft
Moser 12 bolt rear end
30 spline axles
Moser Spool
Also have Eaton posi
4:10 gears
Suspension:
BMR tubular K member
BMR tubular lower A arms
BMR adjustable torque arm
Drive shaft loop
Fuel system:
Pier burg high flow external pump
Aeromotive fuel filters 100 micron before 10 micron after the pump
-8 line to the regulator
-6 return
Aeromotive adjustable fuel pressure regulator
Nitrous:
Cold fusion nitrous set up
Trans brake wired to nitrous so that when you engage the trans brake it turns off the nitrous. When trans brake is released the nitrous is turned back on.
10lb bottle
Bottle heater
Nitrous pressure gauge
Purge kit
Blow down tube
comes with a 22' tandom axle trailer with brakes..
$8,000 OBO
also have:
2004 Suzuki Katana 600
It's Yellow, never been down..
slip on pipe
rejetted
different sprocket
8700 miles
has an extended warranty till september 2007 with 0 deductible through alamo cycle plex in san antonio but you can you use at any authorized dealer..
$5,000 OBO
11.39 all motor
Exterior:
T-Tops
Cowl hood
Interior:
Engine:
LT1 383 Stocker
Scat crank
Eagle rods
12.8-1 compression
Drive train:
30 spline axles
Moser Spool
4:10 gears
Suspension:
Drive shaft loop
Fuel system:
-6 return
Nitrous:
10lb bottle
Bottle heater
Purge kit
Blow down tube
$8,000 OBO
also have:
slip on pipe
rejetted
different sprocket
8700 miles
$5,000 OBO
Re: Kid on the way time to sell some vehicles.....
Dang, I should have bought that car. I have quite a bit more than that just into my engine. And a trailer too? Hell of a deal!
Good luck with fatherhood Ryan. You will enjoy it
Damn, I've seen it before, and that's one hell of a car for $8,000. And a trailor?!
Hell, I'm tempted and I'm a poor college student with absolutely no use for it.
I've never understood this concept. I've never sold a vehicle because I was having a kid.
I have tried to sell the kids a couple of times to buy a vehicle!! In fact I have one right now I'd be glad to sell for the price of say a ZO6.
