FS: Nitrous Works LT1 Wet Plate Kit
This kit is the best-engineered kit for the LT1 powerplant. The freeze-free plate design is compatible with OEM engine components, however, a higher-powered ignition system is recommended. It does not require an additional fuel regulator or upgrade. Adjustable from 75 to 175 horsepower, the system is equally at home on the 1992-1996 Corvette, 1993-1997 5.7L Camaro and Firebird, or the 1993-1997 Impala SS.
Complete: Bolt-on spray bar plate, calibrated jets, solenoids, hose, filter, hardware, instructions, 14 foot/4 AN stainless bottle feed line, and a 10 pound bottle.
4 AN Stainless Bottle Feed Line + Bottle Connector
10 Lb bottle 3/4 FULL
1 Fuel Solenoid
2 Nitrous Solenoids (1 is purge)
Fuel Pressure Safety Switch
Wiring
Jets 75-175
Throttle Body Plate
Throttle Body Bolts
Bottle Brackets
WOT Switch
Stainless Lines for solenoids
All mounting brackets
You will have to supply toggles which you can get at autozone, and I will also supply wiring diagram.
$400.00 OBO Shipped / $350.00 Locally
Michael 972-679-5322
very interested, email me at elynchttu@yahoo.com
My parents live in dallas, so i can probably pick it up too.
thanks,
Eddy
thanks,
Eddy
oldschool
Feb 9, 2016 09:21 PM
