FS: 94 Camaro Z28 Lots of Mods
94 Camaro Z28
Mystic Teal
69,000 Miles
Auto
Factory Options
T-Tops
Cloth Interior
Power Windows
Power Locks
Power Driver’s Seat
Power Windows
Keyless Entry
Electric antenna
RK Sport Ground Effects
RK Sport Spoiler
Suncoast Creation SS Hood
Hyper White Bulbs
Tinted Windows
Interior
Clarion CD with Remote
Pioneer Back Seat Speakers
Auto Meter Dual Gauge Pod
Electronic Fuel Pressure Gauge
Nitrous Pressure Gauge
Wheels/ Tires
Weld Pro Stars 15/8 with 275/50/15’s Nitto Drag Radials (almost new) (rear)
Weld Pro Stars 15/3.5 up font with 165R 15 (front)
Engine Modification
Stage 2 Heads flow 282/206 @.600 (springs, retainers, 1.56, 2.00 Ferrara valves)
Comp Cams 306 230 / 244, .510 / .540 112 LSA
Comp Cams Chromemoly Push Rods
Comp Cams Pro Magnum Non self aligning Roller Rocker Arms 1.6 Ratio
Guide Plates
Cloyes Double Roller Timing Chain
Vented Opti Spark Upgrade
1LE Intake Elbow
K@N Cold Air
160 Degree Thermostat
Tranny Cooler
CSI Electric Water Pump
Suspension
BMR Panhard Bar (Black)
BMR Sub Frame Connectors (Black)
BMR Strut Tower Brace (Black)
V6 Rear Springs
No Front Sway Bar
Vigilante 3,600 Stall converter
Stock Rear end with 3.73’s
1LE Tranny Mount
Fuel
Racetronics Intake Fuel Pump 255
SVO 30 Pound Injectors
Exhaust
Jet Hot Coated Hooker Long Tubes
3 inch True Dual Exhaust X-Pipe, Bullets
02 Sensor Extensions
Ignition
MSD Wires
NGK Spark Plugs
MSD Digital 6 with Wiring Harness
Nitrous (not installed on car)
Basic NX LT1 Wet Kit
Gen X II Upgrade (purge, heater, gauge, blow down tube, fuel pressure safety switch)
MSD Window Switch
Misc.
LT-1 Edit with Cable
LT-4 Knock Module
Alarm
Track Times
1/8 7.66 @ 91.22 1.66 60ft
Pics can be seen at
http://community.webshots.com/user/myslowlt1
E-Mail at
Baricbass@aol.com
Almost all parts have less than 2,000 Miles on them. Jordon Musser did the Heads/Cam install and Tuning. I am sure I forgot to put some mods on the list.
This is Jordon’s website for those of you who don’t know who he is.
www.musserracing.com
www.fastblackcar.com
Asking
11,500
Mystic Teal
69,000 Miles
Auto
Factory Options
T-Tops
Cloth Interior
Power Windows
Power Locks
Power Driver’s Seat
Power Windows
Keyless Entry
Electric antenna
RK Sport Spoiler
Hyper White Bulbs
Tinted Windows
Interior
Wheels/ Tires
Engine Modification
Guide Plates
1LE Intake Elbow
K@N Cold Air
Tranny Cooler
Suspension
V6 Rear Springs
No Front Sway Bar
1LE Tranny Mount
Fuel
Exhaust
Ignition
MSD Wires
NGK Spark Plugs
MSD Window Switch
Misc.
LT-4 Knock Module
Alarm
Track Times
Pics can be seen at
E-Mail at
Baricbass@aol.com
Asking
11,500
Brandon Wittmer
Dec 3, 2014 09:28 PM
