FS 750 Vac sec $125 OBO
Old Feb 15, 2004 | 11:51 PM
NightTrain66's Avatar
750 Vacuum Secondary for sale.
has rear metering block so you can change jets as opposed to the stock metering plate and has the "QUICK CHANGE" kit for the secondary spring.
Looks GREAT
$125 OBO
Old Feb 16, 2004 | 10:43 PM
1965GP's Avatar
Is this something I could put on a car and drive or does it need rebuilt? I have a 455 Pontiac with a Choppin' cam and the quadrajunk just ain't doing it justice.
Old Feb 16, 2004 | 11:53 PM
it has been rebuilt and has not had gas in it since.
If you have the stock intake, you will need an adapter since this is a "square bore" and your Q-junk is a "spread bore". If you have an after market intake, it will probably accept either type of carb.
It is the right size for a 455 and would work well if you have an intake that accepts it.
Lloyd Elliott
NightTrain66@msn.com
GREEN3112
Feb 10, 2019 09:19 PM
Chet1185
Jul 20, 2016 06:09 AM
LT14LIFE
Nov 15, 2015 06:22 PM
drt
Sep 27, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
