EGR failure..........
Old Aug 11, 2004 | 06:38 PM
WickdZ's Avatar
My ECM is telling me that I have an EGR failure. Should I replace it, or block it off? What are the pros and cons of blocking it off?
If I need to replace it, does anyone have a good one that they dont want?
Thanks, Thomas
Old Aug 12, 2004 | 06:25 PM
EviLBoX's Avatar
Re: EGR failure..........
You could try cleaning it with some carb cleaner first. Just remove the EGR valve and spray some carb cleaner in it and work the valve open and closed, it may just be sticking.
Old Aug 12, 2004 | 06:56 PM
JG94Z's Avatar
block it off...there's a brief description of pros-cons on this site.
www.mycamaroz28.homestead.com
J
Old Aug 13, 2004 | 07:24 AM
gun4hire's Avatar
If you live someplace with visual inspections, you better try cleaning it/replacing it.
Good luck.
Old Aug 13, 2004 | 12:48 PM
JG94Z's Avatar
I think it's a pretty difficult part to see...unless they are really looking, they I don't think it should be a problem. I think it was a damn pain in the butt for me...one less thing to have to troubleshoot is always a good thing. Especially since they seem to fail quite often.
Now removing your air pump tubing is real easy to see and very obvious.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
