Not able to burnout? 3.8L Auto
Old 02-20-2005, 02:11 AM
  #16
brink's Avatar
Re: Not able to burnout? 3.8L Auto
my tranny switches great, with the chip it gets to about 5500 rpms and switches very clean..
brink is offline
Old 02-20-2005, 09:33 AM
  #17
easyc4's Avatar
mine shifted fine too, but check your mount, if the mount is going abd, which happens, then the tranny is sitting even slightly low and it will cause a large power loss. does it feel slightly slow upon launch compared to your 3.4? b/c when the mount went, it started to get slower and slower, but still felt like it was running fine. all i'm saying is check it. if its not the mount, then u saved urself 20 bucks, but if it is then u fixed ur problem :P
easyc4 is offline
Old 02-20-2005, 10:38 AM
  #18
brink's Avatar
hmm I will, your right i do take off a little slower, partly due to the fact that i dont have a cat, making my tq less but more hp.
brink is offline
Old 02-21-2005, 03:12 AM
  #19
ChevyTuffD.A.'s Avatar
I dont have a problem doing a burnout and I dont have a cat Car in sig.
ChevyTuffD.A. is offline
Old 02-21-2005, 09:27 AM
  #20
brink's Avatar
yea you've got no cat and an LT1
brink is offline
Old 02-21-2005, 01:45 PM
  #21
sick94's Avatar
Not having a cat is not ur problem. i have a 3.4 and no cat and can burn them all day long w/ out droping the clutch. problem is more than likely ur suspension torqing too much or something. lemme know what ya find out. l8tr
sick94 is offline
Old 02-21-2005, 03:56 PM
  #22
easyc4's Avatar
having no cat would not make enough of a difference to make u feel it. check ur tranny mount, i am 99% sure thats what it is.
easyc4 is offline
Old 02-22-2005, 08:28 AM
  #23
DarkPhoenix's Avatar
It's actually the traction control that is causing that problem. You have to take out the ABS chip, and it hould smoke the tyres right up.
DarkPhoenix is offline
Old 02-23-2005, 11:01 PM
  #24
brink's Avatar
lol I want to have ABS sir..
and suposedly 98 camaros didnt come with traction control -- only 99+ did.
I might try taking the abs out and then trying.
but like i said..
before intake manifold antifreeze leak + exhaust leak it would stop (in 1st gear with the break down) @ 2000 rpm..
after the fixes it stops @ 2500.. this is why i dont think its a rev limiter. / traction control.
brink is offline
Old 02-23-2005, 11:05 PM
  #25
brink's Avatar
but like i said..
again.
brink is offline
Old 02-24-2005, 12:17 AM
  #26
Black94Camaro's Avatar
why would u wanna burn them anyway they just kill your tires and good tires for camaros arent cheap
Its not worth the trouble for you sounds like
ABS.. Chips.. Suspension.. FORGET ABOUT IT
Black94Camaro is offline
Old 02-24-2005, 06:15 AM
  #27
brink's Avatar
b/c i just want to be able to..
brink is offline
Old 02-24-2005, 03:11 PM
  #28
camarobiatch
Guest
Posts: n/a
Not only will it kill the tires , it will screw up your brakes... camaro's are known for ****ty brakes as it is...why would you want to mess up your car? How old are you anyway? The older you get the more you realize that if you want something to last you have to take care of it ...not beat the **** out of it.. I know it took me a few years to be able to afford a new camaro and I dont want to beat it ( like cars in the past) oh by the way,, mine burns out fine after I turn off the ASR button.................
Old 02-25-2005, 05:50 PM
  #29
snakethis69's Avatar
wow dude u have abit to learn if u think the cat is keeping u from burning them, i had a 3800 96 firebird with no cat and a straight back exhaust system and i could burn them all day. i think u should look into the tranny post and the suspension post cause those are most likely ur problems.
snakethis69 is offline
Old 02-26-2005, 08:56 AM
  #30
brink's Avatar
explain how a tranny mount or suspension would keep me from burning out -- ill check into it tho.. maybe ill stop by an auto place after work today..
brink is offline
Quick Reply: Not able to burnout? 3.8L Auto
