CamaroZ28.Com Message Board
-   V6 Tech (https://www.camaroz28.com/forums/v6-tech-22/)
-   -   Misfiring? (https://www.camaroz28.com/forums/v6-tech-22/misfiring-445827/)
merlinx31 Apr 19, 2006 10:43 AM
Misfiring?
This is a long shot because I have been trying to solve this problem forever now. My car has a pretty bad misfire whenever I smash the gas a little especially at higher gears and lower RPMs range (2000-3000). I am not referring about stalling it. It is a couple of quick misfires that seem like an electrical power to me but I've had no luck find it the problem. I have replaced the cat (which was shut), air filter, sparkplugs and wires, I even hooked it up to a computer and gave me nothing. Have any of you guys had a problem like this? It is a shame because other than that she is running like a champ.
1996 Camaro 3.8L (5-speed)
valter Apr 19, 2006 10:49 AM
Re: Misfiring?
Hard to tell for sure, but for 90% :) it's coil(s) or ignition module. Second common problem after plugs/wires. I had to replace my coils on my '96 last year to cure same problem.
merlinx31 Apr 19, 2006 12:04 PM
Re: Misfiring?
oops, I forgot.... I changed the coils too. It actually started running fine right afterwards for about 2 weeks and then it started getting bad again. :confused: Someone suggested it might be the actual computer but I am uneasy about dishing out this much money.
valter Apr 19, 2006 12:36 PM
Re: Misfiring?
Is it misses more in rainy/wet days? Moisture can get through seals under coils to ignition module. Check wires again, so they are tight on plugs/coils and not touching anything hot. Is there any glowing/sparks in the dark under the hood. If coils fixed a problem for a while it may be one of a new coils already went south. Plugs gapped correctly? EGR can be stuck too.
merlinx31 Apr 19, 2006 01:19 PM
Re: Misfiring?
yeah, it get worse on rainny days and I have not seen any glowing at night. I know for a fact that the EGR valve is bad because when I hooked it to the computer it told me. Do you think this could be the problem?
Thanks for the help man.
valter Apr 19, 2006 01:50 PM
Re: Misfiring?
Stuck EGR can cause hesitation/stumbling. It will idle rough too. Your problem looks more like a spark issue to me though.
