D/S replacement
Just got my new one piece drive shaft in. Im going to put in on myself Friday, any tips?
------------------ Black 94' 3.4l Camaro A4 |
Shouldn't be too tough, but if you are removing the two-piece, have fun getting at the "top" bolt at the joint. It's kind of a PITA especially if it's badly rusted. Other than that, 15-30 minute job once the car is up and well worth it too. Drive it before and after and you can really tell.
------------------ Chris Johnson 95, 3.4, m5 custom flowmaster with dual chrome pipes, k+n intake, 1 pc. ds, ES tranny mount, potenzas, tinted windows, rockford and fosgate head unit with a RF 160.2 amp powering a thunderform 10" stealthbox, headlight covers with turn signal blackouts, new centerforce clutch, and more mods on the way! |
Take the eniter rear axle off with the torque arm and driveshaft. then that top bolt is a cinch to get off. http://web.camaross.com/bb/smile.gif
Well it is if you are already swaoiung the rear axle http://web.camaross.com/bb/smile.gif he is right that top bolt can be a bitch. mayeb position a wrench in there, some how, get a hydraulic jack under the car, and put a metal bar between the jack and hte wrench, and use the jasck to force the wrench up starting the bolt. Thats what i would try to do, its really hard to get your fingers in there and it takes elbo grease to get the botl off. ------------------ 1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys Lightest Weight W/out driver: 3160 15.696@86.22 with a 2.214 60'! Best R/T .507 Best 60' 2.106 Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed 15.875@88.25 With wheel spin in 1st AIM: MustangEater82 |
| All times are GMT -5. The time now is 06:53 AM. |
