Car loses power @ WOT
Ok, I driving along and the car is @ WOT. What's weird is that if I slowly let off the gas a little, say I give it 90% throttle. The car starts to pull harder and go faster. What's up what that?
prepare to copy
http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=003428
hope this helps
but your car is older
10 years old, man that is old!
hope this helps
How old is your CAT?
When my Cat started breaking apart, a chunk got sideways under full throttle it clogged and bogged the car doewn but 3/4s throttle it was fine.
Either way with the fuel filter... I owudl change that first, problem or no 10 years old is old!
I am on my 3rd one with a 94.
10 year old fuel filter?
Wow...that is OLD!
When you change the filter, do us a favor...save the filter and cut it open and take a picture!
Even if that isn't the problem, you should see a pretty good increase in drivability.
Wow...that is OLD!
My 95 was running odd so abpout a month ago i changed it it was the one straight from the actory lol i put my mouth on one side and couldn't even breathe through it. and when i unhooked it from my furl lines it freaking leakedblackgooonmyit was nasty but i put a new one in and it fixed that same problem
after u change your fuel filter if that doesn't fix it, pull your plugs out and check them, if they are all carboned up have your fuel injectors checked. i had the same problem and spent alost $2000 replacing things before i found out that the injectors were leaking. if i floored it, it just sorta died and sputtered, and if let off a bit, it would push me back in the seat. good luck
Originally posted by BradC
How can I tell if the cat is clogged? It's OE.
