Alternator???
Alternator???
ok guys, i have a 95 3.4L camaro.. Last night i was driving and the check gauges light comes on so i look around n see my volts gauge has dropped by a significant amount. i turn the car around n go home.. thought maybe it was a loose connection at the battery terminal, but theyre all tight.. we used a voltmeter on the battery and it was getting 12.5 volts which is alright.. im almost positive its the alternator (cars got 123xxx miles on body n 3k on engine) what do u think?
Re: Alternator???
If your car starts up with no problem, it is the alternator.
And since you already tested the voltage on it, it is 99.9% likely it is your alternator.
It is easy to replace though.
Re: Alternator???
yea theres 123k on the alternator.. i have a jasper rebuilt block.. i was pretty sure it was the alternator because for the past few months the volts would spike all the time..the car does start up fine so i guess i'll throw in a 160 amp alternator in to keep her happy.. thanks guys
tommalcolm
Sep 11, 2015 03:39 PM
