Alarm trouble...Help
Ok this is the problem.When I lock my doors and start to walk away the alarm goes off.Then I hit the lock button and it stops and works like it should.I have a 1998 V6 RS.Anyone know anything about this?It's driving me crazy!
Thanks in advance.
Scott
Thanks in advance.
Scott
There's a small white sensitivity **** on the shock sensor in the spare tire area - it doesn't turn much, but counterclockwise turns it down. If that doesn't work try unplugging the sensor and see if it goes away - if it does the sensor is probably bad, check to see if water somehow got to it also.
MichiganSkip
08-06-2015 09:38 AM
