Ticking sound
Old 05-04-2017, 09:35 AM
Old96er's Avatar
Ticking sound
Hello,
I hear a ticking sound from the left side of my 3800 that I only hear when the car is moving. It sounds like a lifter tick tick tick but I don't hear it when the car is idling in drive or even in neutral.
Aside from that, car runs great. It's a 1996 with only 70,000 miles.
Any thoughts as to what it could be? And if it is a stuck lifter, is that something that should be addressed? I really don't want to invest money in an engine rebuild on this thing and I can live with the noise if it's not that dire.
Thanks in advance for your insight!
Old96er is offline
Old 05-04-2017, 10:27 AM
Re: Ticking sound
"Ticking" can be due to an exhaust leak. Have you checked that possibility out?
Injuneer is offline
Old 05-04-2017, 11:13 AM
Old96er's Avatar
Re: Ticking sound
Y'know, I'm glad you said that because I thought of that. Maybe an exhaust manifold gasket. I'll look into that. Thank you!
Old96er is offline
Old 08-31-2017, 02:38 PM
kallcium's Avatar
Re: Ticking sound
If its not exhaust, in my old v-6 I had changed the fuel injectors and noticed a tick sound. It ended up be natural for those fuel injectors but I only noticed it because I tend to listen hard after you fix something and that sound was always there but I was just noticing it then.
kallcium is offline
Old 10-30-2017, 03:08 PM
Javelin3o4's Avatar
Re: Ticking sound
My 3800 has a tick on the passenger side. I thought maybe it was the pcv valve in the upper intake.
Javelin3o4 is offline
Old 11-03-2017, 05:29 PM
Bird_Of_Prey's Avatar
Re: Ticking sound
If the ticking increases with engine speed, it's probably not the PCV.
Bird_Of_Prey is offline
