Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Killing spree tonight...
Old Nov 14, 2007 | 04:36 AM
ZONES89RS's Avatar
Well, i expected to get to make a run or too, but 5? My clutch needs a break!!!
1st, i raped my buddys LT1 vette, wasnt ****...
2-4 were all WS6 LS1 TAs with boltons, as usual 3rd gear did its thing and it was tail lights fade.
#5....this was my challenge. A new EVO, has int., exh., cams and tuned. This thing ran HARD, from a 40 roll he jumped me, i was down to his back bumper and quickly thinking this rice was about to take my pride, then as he would shift he fell back a bit, then once i hit 3rd gear i was pulling him back. Next thing i know i am a half a car on him. I was happy i didnt lose to him, i wanted to make him look bad in front of his hot *** asian girl friend.
This thing would rape me from a dig, i think there is no way i would make it up on the big end. Nice car though, good fun night with no complaints except my buddys 91 RS leaking fluid from the front seal, dummy doesnt have a PCV valve it any crank case venalation at all, go figgure.
Old Nov 14, 2007 | 11:29 AM
Marc 85Z28's Avatar
You're outrunning bolton LS1s at higher speeds with this:
Fully built 355 motor... 9.7to1 compression, ported and polished 70s heads, Comp cams XE 274... performer intake, 750 Holley, Hedman full lengths with custom Y-pipe with dual cut outs, Flowmaster crossflow muffler, Open diff swapped for a 2.73 posi
I've got a very similar setup in my Z28, only difference being a Performer RPM, World Products heads, and 3.42 gears. My car runs strong (mid 12s @ 108-109), but won't pull bolton LS1s at higher speeds. Ever run your car?
Old Nov 14, 2007 | 11:41 AM
ZONES89RS's Avatar
Havent run it at the track yet. I did not change the mods since the new motor, it has a air gap RPM and a comp XE roller with 236/242 .050 and 520/540 lift. Those heads are heavoly ported and polished too.
Old Nov 18, 2007 | 12:08 AM
ZONES89RS's Avatar
My buddy went to the track in hid LT1 vette, he ran 13.50s, i thinkj i might be low 13s then, ill see one day.
Old Nov 19, 2007 | 12:03 PM
bombebomb's Avatar
Nice kills!, nothing like a list of kills when you come home
Old Nov 20, 2007 | 12:12 AM
ZONES89RS's Avatar
Man, i was gonna be happy to get a few runs in, so it was kina overboard for one night for me. Mu budget *** little motor is holding together well, i bet it doesnt have 500 miles on it yet!
Old Nov 20, 2007 | 02:00 PM
Superfly95Z's Avatar
I know anything can happen on the street but if you think you're running low 13's there's no way you could be pulling bolt-on LS1s on the top end. Most bolt-on LS1s easily dip into the low 13's, sometimes high 12's with DRs and a good launch. Not saying anything bad about your car, it sounds like you did a good job with it. Go to the track and get some times on it.
Old Nov 20, 2007 | 07:35 PM
ZONES89RS's Avatar
True, true, they all pulled me by a nose clip out of the hole, then i chased them down on the big end pretty easily, i NEED to get a gear before the track is an option. Now that you mention it, i guess it could be a high 12 second car, i will let you guys know when the day is here, but with the hollidays, the ol girl is kina put on hold.
Old Dec 20, 2007 | 07:48 PM
1BadAzzGT's Avatar
+1
Old Dec 23, 2007 | 12:11 PM
rickreeves1's Avatar
Man I beat my buddies Honda the other day. He said he runs 11's at the track. I must have a 10 second car. Now that I think about it I guess it could be a high 9 second car.
Old Dec 23, 2007 | 12:47 PM
Demon's Camaro's Avatar
See the difference? One is a definitive.
We will just have to wait and see what he runs.
Old Dec 23, 2007 | 01:29 PM
I see guessing of track times from street races.
Old Dec 25, 2007 | 11:18 AM
ZONES89RS's Avatar
Well, i did see the time slips, his vette runs great and i stomp LS1 cars with a couple of bolt ons s o you can assume low 13s, i will deffinatly post slips when i make it to the drag strip.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
jwade88
Jun 14, 2015 09:38 PM
Hobbyguy
May 26, 2015 02:15 PM
beltrunner
May 17, 2015 10:18 PM
TEG99SS
Apr 11, 2015 10:08 PM
