Will True Duals Clear BMR Trak Pak???
I figured on spending the extra money on the trak instead of the regualar TQ arm but will true duals clear cuz i really dont want to run anything other that true duals?
thanks, -john |
Re: Will True Duals Clear BMR Trak Pak???
It should clear it fine. Do you have the torque arm installed already? If not, then do that first or it will be extremely difficult to do it after the exhaust. I have the adjustable torque arm and everything clears it fine. Now you mentioned the track pack, that arm is a little beefier right? But it should still work.
thanks for the info, I dont have any of the stuff installed yet but soon. thanks, -john |
I don't have true duals, but I do have the track pack and I can't see how true duals would clear it unless you dumped it before the xmember. There are provisions for the I pipe to go above the xmember, but there is no way that I can see that 2 would fit. Go to BMR's website and look at some pictures.
