Where do the washers go on my bolt in LCA relocation brackets?
Old May 6, 2007 | 08:05 PM
KillerTA's Avatar
Question Where do the washers go on my bolt in LCA relocation brackets?
I already installed them and put the washers on the outside of the bracket on the new bolt that bolts to the old location of the LCA.
I also installed them with the wheels off of the ground and the LCA didn't line up that great. The mount for the shock on the new bracket didn't line up that good on
It would have been nice if J&M included some instructions
Old May 6, 2007 | 09:17 PM
hotpart's Avatar
Former Vendor
Sorry you didn't get instructions, we can most certainly email you some if you still want them. The washers need to go on the outside just like you did it. As for the alignment the rear-end almost always moves when the lca's are disconnected so the line up of the holes is not that uncommon. The shock mount is designed to be a very tight fit so there isn't any movement in that area once it is installed. We find it easiest to place the shock mount tab in place and then rotate the rest of the bracket upward into position.
Espo
Aug 22, 2002 06:57 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Waste
Jul 31, 2002 11:59 PM
twistedwedge
Jul 27, 2002 01:54 PM
