Torque arm fitment problems
Hey guys,
I got a bit of a weird issue here- I have a 2002 Ls1 Camaro and I am trying to swap in the tunnel mount torque arm from sphon into the car and it doesn't seem to want to clear the exhaust.
The car currently has stock Headers, stock Y-pipe and a corsa catback.
I have the normal straight torque arm crossmember from sphon as well as the longtube style one that I picked up for when I eventually swap on Lt headers next year.
BOTH don't clear the factory exhaust with the safety loop...now I know the straight crossmember cleared my old v6 Camaro just fine, so what is the issue here?
When I put the straight crossmember into place I can't get the bolt holes to line up because the driveshaft safety loop hits the exhaust. It looks like it needs to go about another .5 - 1 inch over to the passenger side of the car.
Any thoughts?
Any thoughts?
Re: Torque arm fitment problems
my fix might be to chop the safety loop off at this point, get the arm on, drive it to the exhaust shop, chop the factory Y-pipe and mcgyver it around the loop and weld everything back together.
Might cost me $230 this way vs doing the LT headers and Y-pipe right now...either way it is a **** off...
I purchased a UMI toque-arm mount for a 97SS T56. Trans mount did not align. Hole off 1 dia. Also, Torque-Arm off about 1/2 inch. I cut and reworked. Fit nice now. Better trans bushing mount now. Had to add more shims (1/8). Also, made changes to make it better @ torque arm. Still don't like alignment. I have better ideas. Dangerous with welders. I don't know what to tell them? Thinking not. B.
