CamaroZ28.Com Message Board
-   Suspension, Chassis, and Brakes (https://www.camaroz28.com/forums/suspension-chassis-brakes-47/)
-   -   torque arm? (https://www.camaroz28.com/forums/suspension-chassis-brakes-47/torque-arm-539105/)
maro z28 08-21-2007 11:25 PM
torque arm?
Can anyone help explain exactly how a torque arm helps traction? I know it holds pinion angle, but beyond that I don't even know what it really does.
Z-RATED94 08-22-2007 08:38 AM
With a chassis mounted adjustable TA you can make sure you have a little negative pinion angle for the track. You can buy a trans mounted one that will do the same thing, but from what I understand the chassis mounted one does a better job. Something about being able to adj. the instant center of the chassis better. Do a search, the details are over my head.
Jeremy95TA 08-24-2007 11:11 PM
Try a search. Injuneer has some great write ups on here.
