Spongy brake pedal
I recently had the 2 brake lines that lead to the ABS system replaced. The problem now is I have a spongy brake pedal, it will stop if I slam on the brakes. Is a brake bleeding in order? and dif this still doesn't cure, what could be the problem?Thanks ahead of time
Re: Spongy brake pedal
You have air in the lines; your system needs to be bleed until all the air is out of the lines.
Yea dude i wouldnt rive until you bleed them. Why didnt you bleed them right after you replaced them? :confused:
My collective knowledge of fixing cars can fit in a pinbox and rattle around people.
