help - brake light on
Old 06-21-2016, 05:56 PM
95LT4Z28's Avatar
my brake light is on. unplugging the emergency brake did not help. i did a abs delete a while ago. light was not on. was recently had the console out. any suggestions?
95LT4Z28 is offline
Old 06-21-2016, 07:07 PM
Re: help - brake light on
The "BRAKE" light has a dual purpose - the e-brake, and also indicates unequal hydraulic pressure between the front and rear braking circuits. The pressure switch is in the block on the side of the ABS motor pack, that the front and rear brake lines from the master cylinder connect to. What did you do with that block/switch when you deleted the ABS?
Or maybe you pinched the e-brake switch harness wires and shorted them when you were working on the console.
Injuneer is offline
Old 06-21-2016, 07:13 PM
95LT4Z28's Avatar
thanks for the quick reply. i removed the abs module and block in one piece. grounded the lt green wire to keep the abs in op light off. i do not think my brake light was on after i did the delete.i must have done something when i was messing with the console
95LT4Z28 is offline
Old 02-19-2018, 04:47 PM
95wannabe's Avatar
Did you ever figure out your brake light problem?
I too have removed ABS and have both the ABS & BRAKE light on. Here's a shot of the couple connectors I unplugged. I don't see what I would call a light green wire on them. Is it the green wire in the middle in the first pic?
95wannabe is offline
Old 02-19-2018, 10:32 PM
95LT4Z28's Avatar
yes i did get it straightened out. i needed to unplug the ebcm module that is under the drivers side dash. I had to ground the light-Green wire @ the EBCM to fix the brake light on problem. i think what you (and i ) unplugged is where the abs motor was.
95LT4Z28 is offline
Old 02-20-2018, 05:32 AM
95wannabe's Avatar
Oh ok, yes you're right, these are the connectors at the ABS unit underhood. I'll look for the EBCM under the dash. Thank you very much for that!
Did you also have an ABS light on?
Old 02-20-2018, 10:31 AM
95LT4Z28's Avatar
if i remember correctly the abs light went out when i unplugged the ebcm. the brake light went out when i grounded that green wire. good luck
95LT4Z28 is offline
Old 02-20-2018, 11:59 AM
95wannabe's Avatar
Awesome thanks!
I'll report back either way
Old 02-21-2018, 05:39 PM
95wannabe's Avatar
Hey thanks for that info...I unplugged the EBCM and the BRAKE light went out. Grounded the Lt grn wire and the ABS light went off. One of the two also turned off my LOW OIL light.
Thanks again!
FULL DISCLOSURE: my car is an LS swap
Old 02-22-2018, 04:16 PM
95LT4Z28's Avatar
glad you got the brake light issue straightened out but i do not think the EBCM has anything to do with the low oil light
95LT4Z28 is offline
Old 02-22-2018, 05:58 PM
95wannabe's Avatar
yeah I wouldn't think so either, but I wonder what that lt grn wire is exactly....hmm
malibudave
06-28-2017 01:05 PM
95z_28_camaro_4_Ivan
10
08-03-2016 04:49 AM
force10
07-07-2016 08:10 AM
bbreeze93
Parts Wanted
06-05-2016 11:04 AM
ZoomZoom
06-02-2016 08:51 PM
Quick Reply: help - brake light on
