quick LCA installation question
Last night I ordered a set of LCAs from J&M. Is it best to install them with weight on or off the rear wheels? Is there anything special I need to know when installing them? They look like they're pretty straight forward. I just want to make sure. Thanks!
do one at a time, other than that its straight forward, simple
did mine with jack stands and floor jack |
Its going to be very difficult with the car sitting on the back wheels. The LCA is the only thing keeping the rear axle assembly from moving forward and backward under the chassis. The weight of the body resting on the wheels is going to move the axle a bit when tou remove the LCA, and then its going to be very difficult to get the axle back in the position where the bolts will go back in. Put the subframes on jack stands, and support the bottom of the differential with a floor jack.
Originally Posted by slowride94z
(Post 5579797)
cool! Thanks guys!
