QA1 single adjustable fronts, settings?
OK, so I ordered QA1 single adjustables from the board classifides, well they just arived, and I need to prepare for installing this weekend. I guess I need to read up on the install now...
I have read however that you guys mention different settings like 6 or 4 and so on, but the dial just has a + and -, can I assume the minus is 1 and the lightest setting and + going stiffer? I haven't played with them or anything just unpacked, inspected, and took pics (with the cat wanting to help inspect the new parts)... http://www.1slowformula.com/images/s...ith_parts3.jpg http://www.1slowformula.com/images/s...with_parts.jpg http://www.1slowformula.com/images/s...ith_parts1.jpg Now the detail shots. Shocks: http://www.1slowformula.com/images/qa1_fronts3.jpg http://www.1slowformula.com/images/qa1_fronts1.jpg http://www.1slowformula.com/images/qa1_fronts2.jpg Springs: http://www.1slowformula.com/images/qa1_275_springs.jpg http://www.1slowformula.com/images/qa1_275_springs1.jpg http://www.1slowformula.com/images/qa1_275_springs2.jpg Bearing kit: http://www.1slowformula.com/images/qa1_bearing_kit.jpg |
6 or 4 means the amount of clicks from the low setting (the - ). Toward the + is stiffer.
Thanks Rob, that's what I thought but wanted to be sure...
