Power steering fluid shoots fromt the resevoir...
What the ****. When I turned the wheel with the motor off, it shoots up from the cap of the resevoir. (This is on a 1991 Ford Bronco if it matters). Is this normal. The local mech. said its normal for Fords.
Re: Power steering fluid shoots fromt the resevoir...
i've seen it happen on a 94 mercury cougar
the system still works fine so i guess its ok
how often do u turn the wheel when the engine isnt running?
I was turning the wheel so I could get to the brakes so I could bleed them.
I also notice that there a ALOT of play in the steering when I am driving. I can almost turn the wheel 90* before I get any response. Almost took out a mailbox because of it the other day.
If you have excessive play in the wheel I would check into a new steering gear box. Odds are the gears and bearings are worn allowing excessive play in the steering system.
carguyshu
01-22-2017 11:19 AM
stockssn2o
05-25-2015 08:54 AM
SMO Q
02-11-2015 07:13 AM
