optimal relocation?
got the intrax springs and of course the wheel hop has commenced to complete annoyance.. so my question is how much should i drop the rear lca mount.. i can fab just about anything so that isnt a problem.. i am about to put sfc, lca, phb and poly bushings in but i was just wondering waht the BEST amount to drop the lca brackets is.. any help would be appreciated..
Re: optimal relocation?
Originally Posted by Fast Orange
got the intrax springs and of course the wheel hop has commenced to complete annoyance.. so my question is how much should i drop the rear mount.. i can fab just about anything so that isnt a problem.. i am about to put sfc, lca, phb and poly bushings in but i was just wondering waht the BEST amount to drop the brackets is.. any help would be appreciated..
so no one has any actual measurements???
1/2"??? lol.. the other guy says even or below the front mount.. in my case its gonna have to be more like 4 or 5 inches to be even or even close to level.. yeah thats right i did say inches.. just a stock suspension with intrax springs.. supposedly a 2" drop..
dammit im a moron.. sorry bro.. does the 4to5 inches seem abnormally low?
It will actually depend on what you want to use the car for. If it's more for taking turns, than it needs to be level, or the front slightly lower than the rear. If ot's strait line traction you're looking for, then you want the rear slightly lower than the front.
I would recommend some rod-ened lower control arms to get rid of the hop. You can get away with poly bushings there if it's for drag purposes. |
it is for traction purposes.. no rod ends for me.. they just wont live with the amount of driving i do.. i plan on using dalron for bushings.. thanks for the help guys..
well from what ive seen you still only get maybe 10k miles out of a set.. for a daily driver i think the dalron will work find..
which brand do you reccomend?
makes sense.. aprecciate the help..
