need help with brakes!
Old Mar 17, 2005 | 06:52 PM
warhead20022002's Avatar
1998 camaro, disk brakes all around. my car is only stopping with the front brakes only. i was told it was a valve or something. i lifted the back wheels and i put it on drive and i pressed the brakes hard and the back wheels didnt stop at all. and when i drive and stop the front sinks too much.
help would be apreciated.
Old Mar 17, 2005 | 07:15 PM
funina91ss's Avatar
Re: need help with brakes!
I would try bleeding the bakes first before replacing anything. Also check your pads when you have the wheels off.
Old Mar 17, 2005 | 09:08 PM
blackztpi's Avatar
check your back calipers, and if the pistons are moving in a out. also make sure the master cylinder is pumping to the back brakes. let us know from there
Old Mar 18, 2005 | 09:17 PM
i will try that as soon as the weather clears up. i will keep u guys posted.
but thanks for the help.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
