ls1 brakes
i was wondering if i installed ls1 brakes in front, would i need an ls1 line lock kit then or would the lt1 work?
Also would the ls1 rear brakes work with my moser 12 bolt? Thanks Andrew |
Re: ls1 brakes
The line lock kit splices in closer to your master cylinder. Stick with the LT1 kit, the kit doesn't care what's downline. ;)
Re: ls1 brakes
That's what i was thinking but i figured i'd ask to make sure:cool:
Thanks!! What about the rears? or should i not do them? |
Re: ls1 brakes
I wouldn't worry about the rears. The fronts is where the Big gain is. :)
Re: ls1 brakes
I agree with compstall, don't worry about upgrading your rear brakes with ls1 parts. A good set of slotted rotors all the way around and new ceramic pads plus a good brake bleed will do wonders for any brake system. Have fun with your new ls1 fronts.
