Eibach Install
Eibach Install
Ok, I am going to attempt the spring/shock install myself. I have rented the strut compressor from autozone, and have all the sockes, electric impact wrench, and jack. I can get the wheels about 5 inches off the ground.
I am very competent when it comes to mechanical stuff. But i have never done springs before. Can anyone give me some advise? pointers? any help at all. any extra tools i will need?
tool list:
Jack
jack stands
6 pack of miller lt.
hammers
impact wrench with sockets
torque wrench
another 6 pack of miller
penetrating oil
spring compressor
12 pack miller
bandaids
neosporen
bottle of vodka
does this about cover it for tools needed? Can i find the step by step in my hayes book?
tool list:
Jack
jack stands
hammers
torque wrench
penetrating oil
spring compressor
12 pack miller
bandaids
neosporen
bottle of vodka
Re: Eibach Install
Originally Posted by OBE1 95Z28
Here's a good write-up: http://www.houston-f-body.org/tech/shocks/index.htm
Re: Eibach Install
Thanks. I am not too worried. I rented the strut compressor from autozone, and i have all the other tools necessary. I am very good mechanically..so that wont be a problem. I am putting in alot of parts at once:
Eibach Pro-Kit
Bilstein II shocks/struts
Hotchkis LCA's
Hotckis Panhard
BMR relocation bracket
this should be a fun 2 day project with alot of beer and bandaids...i am just waiting for the relocation brackets to come it. so it should all be in either this weekend, or next.
wish me luck!
p.s. any pics?
Eibach Pro-Kit
Hotchkis LCA's
Hotckis Panhard
wish me luck!
p.s. any pics?
Re: Eibach Install
Okay, I'm not even close to mechanically gifted. So I had some pro's do the compressing for me. But I did the rest.
The one thing I found that I did wrong on the right front was to tighten up the top first. I then had a helluva time getting the new Bilstein's bottom mount to twist into position. But I was stubborn and got it done.
So on the left side, I started the nuts on the bottom before even beginning on the top. Went in like a breeze! I didn't think it would, that's why I did it the opposite way on the other side.
Anyhoo, that's all I can offer.
Re: Eibach Install
Eibach Pro-Kit
Hotchkis LCA's
Hotckis Panhard
wish me luck!
p.s. any pics?
Eibach Pro-Kit
Hotchkis LCA's
Hotckis Panhard
wish me luck!
p.s. any pics?
If you want much better than stock handling, send back the lowering springs, just do the Bilsteins. If you want killer handling, send back the Bilsteins AND the lowering springs, get the koni DAs, and put a 35 mm sway bar up front.
If you want drag, there's other approaches... but what you have will give you none of the best of anything.
Re: Eibach Install
There are THOUSANDS of SSes out there that came with lowering springs and Bilsteins. There are thousands more F-bodies whose owners have switched to Bilsteins. In 12 years of 4th Gen F-bodies, this is the first time I've ever heard anything bad about Bilsteins--and not even from personal experience.
With so many thousands of successful applications out there on the road, I'm not going to put a lot of stock into one guy's claims which are based on... Well, I don't know what they're based on.
Re: Eibach Install
this is the first i have heard of this 'bad combination'. everywere else, and everone else said this was a good set up. not to mention SLP where i got them. Let me pull this directly from the SLP site...
sorry...but i dont agree with you. I think the car will handle superbly.
This new package combines our #70008 Bilstein shocks and #70009 Eibach springs to create the ultimate dual-purpose suspension upgrade for 1993-2002 F-Bodies. Custom-designed to SLP’s specifications by their respective manufacturers, these pieces fuse race-quality responsiveness at the track with a firm but comfortable ride in everyday use. Best of all, you’ll save more than $20 over the cost of buying the parts individually.
Re: Eibach Install
all done...and...with all my headaches, and being the first time i have done this, took me a full day to complete. not as much bandaids as expected, and no beer yet
but let me be the first to say...damn that biatch is LOW!!! i will get some pics up tomorrow...
its 5 am now...im off to bed.
and yes, i know this is a double post, but its just for the people who were already on this thread...
but let me be the first to say...damn that biatch is LOW!!! i will get some pics up tomorrow...its 5 am now...im off to bed.
Re: Eibach Install
how long does it take for all the springs/shocks to settle? it seems like there not all even yet...and it seems like one of the rears is riding pretty low. is it possible that i dont have the springs seated right on the rear? there was no stopper, they just sit on the metal.
Re: Eibach Install
Double check the the upper spring isolators are properly positioned. Also make sure the ends of the coils on the bottom of the springs are pointing the same direction on both sides of the car.
Re: Eibach Install
how long does the settleing take? should i wait to get the alignment till after that? Is there a reason why i hear a clanking sound every now and then when i hit a bump? ( I just took all the wheels off and dbl checked all the nuts & Bolts...everything is good, and properlly torqued down?.
but it handles sooooo much better. no regrets there...
