Double Adjustable PHB.... Something missing? (W/Pics)
Last night I decided to install PHB relocation kit and a double adjustable PHB. So I got the PHB relocation kit on, and went to install the PHB and noticed something was missing :confused:. So I snapped these pics. Can any one tell me where I can get some spacers?
http://i222.photobucket.com/albums/d...1/PA040264.jpg http://i222.photobucket.com/albums/d...1/PA040263.jpg http://i222.photobucket.com/albums/d...1/PA040262.jpg |
There should be a solid spacer on each side of the "ball", this will provide the corect deminsion to match the stock arm. You can fab these by getting some big nuts and drilling them out to fit your bolt then grind them to the desired width. I did this for my used Spohn torque arm which was missing just one of the spacers I mentioned above.
Tolerances in these spacer are NOT super critical. |
You should be able to get spacers from any vendor who sells rod end phbs. The bushings should eliminate any gaps between the rod end hole and the bolt diameter as well as between the rod end and the brackets.
The spacers should stick out of the ball by 3/4" on each side. You could make some yourself by getting some thick wall tubing and cutting it into 3/4" sections. It wouldn't be the prettiest thing but it would work and be cheap.
