Can't get rid of the squeaking
Subscribe
Apr 15, 2005 | 08:57 AM
I just changed the back rotors to the IRotors cross drilled and slotted set up. I used O'Reilly brake pads. I cleaned everything, and greased the pins in the bracket and the pins that the pads sit on. I still get that damn squeaking while stopping. It does it as I start to brake (normaly) and quites when I push the peddle down harder. I am at my whits end here.
Any suggestions?
Reply
Apr 15, 2005 | 04:03 PM
Re: Can't get rid of the squeaking
Put factory Pad good old AC delco if you do the search for a squeak i posted the part # for the pads in another post like yours hope this helps.
Reply
Apr 15, 2005 | 04:13 PM
I did a search under your name and came up with no part number. Can you post it up?
Reply
Apr 15, 2005 | 10:19 PM
I called O'Reilly right before they closed and asked them about swapping out the pads. He asked me what type did I have on their now, I told him the BrakeBest ones (white box). He told me that for my car I need to get the ceramic pads (forget what he called them). The BrakeBest pads are organic and will squeal. I told him that no one told me that when I orginally bought these. He said they usually don't unless you know for sure what you want. He told me I could upgrade the rear pads for an extra $20 and the fronts for an extra $30. So I guess I am going to try this route and see what happens.
Reply
Subscribe
