Are all 93-97 V6 suspension components same as LT1???
Old Nov 18, 2004 | 10:45 AM
Camaro_Guru16NY's Avatar
Im redoing my entire rear suspension this winter with mostly BMR Stuff and am wondering if all of the V6 stuff im taking off is the same on Z28s not including shocks and springs, I know those arent the same. But are the LCA,s K member, upper and lower A's, etc the same. Like i said im replacing all of the rear components with BMR and if the stock parts are compatible then it will make it easier for me to sell the stock stuff off.
thanks,
-john
Old Nov 18, 2004 | 10:59 AM
Camaro_Maniac63's Avatar
Re: Are all 93-97 V6 suspension components same as LT1???
The K-member, and the front sway bar are also different.
Old Nov 18, 2004 | 09:51 PM
ExStyle's Avatar
Of course if your putting an lt1 in the difference in k-members is good ... so the lt1 will mount up.
Old Nov 18, 2004 | 10:17 PM
So basically the only parts that are different are the K member and sway bars then right?
-john
Old Nov 18, 2004 | 10:31 PM
MustangEater82's Avatar
as far as I know...
shocks, springs, and rear sway...
front sway on 93-97 is the same as stock on a z28. both of them 30mm. but the rear is 17mm while a z28 is 19mm
as a tip the sways are an upgrade for 98+ v6, the have 28/15 mm sway bar combo.
Old Nov 19, 2004 | 04:14 PM
SageofKnight's Avatar
Torque arm is different. The V6 one has extra bracing for where the 2-piece driveshaft connects.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
guionM
32
Aug 19, 2002 01:39 PM
Trevor98ramair
Jul 31, 2002 02:43 PM
