they're expensive
they seem to be good with handling and being able to raise and lower the car is nice
with 4th gen camaros you can adjust ride height and preload on the spring as well as dampening in the shock absorber
the kit is expensive enough without a controller system
air ride technologies can send you a free catalog, http://www.ridetech.com
downside is cost and installation although it's not too bad but you should have some experience around the garage.
upside is adjustment... set it for whatever you like. your not going to win an auto-x next to a solid spring car but you can still have fun while keeping up.
suggestions. invest in every brace upgrade possible. sway bars, stb, lca's, everything as you need to be able to dial in your normal driving height. after that it's great but expect to pay close to 5,000 after install to have it perfect.
