best deal on AFR,JESSEL,EDELBROCK?
Hey everybody
who can give me the best deal on
AFR 227
EDELBROCK LT4 INTAKE
JESSAL SHAFT MOUNTS
vendors shoot me Pm with deals
AFR 227
JESSAL SHAFT MOUNTS
WD
Just to double-check the part numbers I called Jesel a few days ago. They told me "only" their Competition Series part number KCS-313121 rockers will work on my AFR LT-4, 195 street heads which were manufactured in 2005 or 2006. (????)
I also called AFR, they “think” (but not completely sure) the Sportsman Series for 23 degree SBC heads (same number you gave me) should work on my AFRs. The price you quoted is very good and I would like to use the Sportsman Series Jesel rockers. However, I first need to be absolutely sure I’m ordering what will work with the AFRs.
Also, I plan to use custom 3/8” push-rods and I know the rocker offset can be an issue with the push-rods rubbing the heads if everything isn’t correct.
Thanks,
WD
Thanks,
WD
Just spoke with Jesel and the 23 degree kit for the Sportsman Series "should" work. I also got a price on the new AFR LT1/4 Competition kit. They do not have a specific LT1/4 listing in the Sportsman Series.
Jesel Sportsman Series
Part Number KSS-336060
$825.00
Jesel Competition Series
Part Number KCS-313121
$1249.99
$825.00
$1249.99
